FromSolidDef Method
Hi All,
I hope you are well.
I was wondering if using the FromSolidDef method when developing zero-touch nodes in C# is possible. I have tried without much luck. My goal is to draw a few shapes in Revit, store them as strings, and then use the FromSolidDef method to recreate them. This approach would be much easier than modelling the shapes directly in Dynamo.
Thanks for your help!
@john_pierson @chuongmep
I can confirm it’s doable; You may have better luck with other methods though (i.e. SAT / SAB, where you just consume the path to the file in your zero touch node), depending on your geometry type.
Ahh thanks Jacob. I will give this a go.
It posible, just remember is you need to import library before use FromSolidDef
using Autodesk.DesignScript.Geometry
Hello
Yes I did so. It does not work.
can share what you did ?
Hello
Sorry about the delayed response.
It seems the issue was that the fromSolidDef method can only be called in a static method. I was attempting to use it in an instance.
Thanks.
