From 2 list create 1 combined
I have 2 list. I want to create 1 with the values from both list with the same index.
list1 list2 combined
0 01 0 A 0 A-01
1 02 1 B 1 B-02
2 02 2 B 2 B-02
3 04 3 A 3 A-04
thanks Edwin.
you can try adding them like this:
@EzDoesIt I’d go with @viktor_kuzev’s suggestion
However, if you really want to use String.Join
or in python:
OUT= [str(i)+"-"+str(j) for i,j in zip(IN[0],IN[1])]
Hello, I’ve tried your suggestion to combine the 4 lists, and something gos wrong with my lists (I’m really new at dynamo!!)
I just want to take one point by one of each list to create a polycurve,…Could you help me?
Thanks in advance
Greg
@GREG_RVT you’re feeding points into a node that deals with text.
Thanks for your answer @viktor_kuzev, as I said, I’m a very new architect in dynamo’s world; anyway I need to make a façade using dynamo. Now, I’ve tried whith the Code Block from @Vikram_Subbaiah, and I got what I wanted, each element from the list are 4 points, but right now, I can’t make a simple square with those points!
Thanks in advance
Greg
@GREG_RVT You’ll need to group and sequence your points properly
Hope the generic example below helps
l1=Line.ByStartPointDirectionLength(Point.Origin(),Vector.XAxis(),50);
l2=l1.Translate(Vector.YAxis(),10);
l3=l2.Translate(Vector.ZAxis(),5);
l4=l3.Translate(Vector.YAxis(),-10);
p1=({l1,l2,l3,l4})<1>.PointAtParameter((0..1..#5)<2>);
