Formatting excel data types for family parameters
Hi - I’m trying to format some excel data for input into family type parameters (that are shared), and keep getting “The parameter’s storage type is not a number”. In the screenshot, I have compared the object.type for both my excel data and the parameter storage types - they appear to match, other than the python node outputting System.* types instead of native Revit integers, doubles, etc. Is that what is causing the issue? You can ignore IN[0] in the python, it’s not doing anything yet.
import sys
famtypes = IN[0]
params = IN[1]
# Format parameters
for param in params:
	# ID
	param[0] = str(param[0])
	# Name
	param[1] = str(param[1])
	# Depth
	param[2] = float(param[2]/12)
	#Height
	param[3] = float(param[3]/12)
	# Width
	param[4] = float(param[4]/12)
	# Weight
	if param[5] == None:
		param[5] = 0
		param[5] = int(param[5])
	# Counter or Floor
	if param[6] == None:
		param[6] = ''
		param[6] = str(param[6])
	# Relocated?
	if param[7] == None:
		param[7] = 0
	elif param[7].lower() == "y":
		param[7] = 1
		param[7] = 0
	# Location
	if param[8] == None:
		param[8] = ''
		param[8] = str(param[8])
	# Power
	if param[9] == None:
		param[9] = 0
	elif param[9].lower() == "y":
		param[9] = 1
		param[9] = 0
	# Dedicated Circuit
	if param[10] == None:
		param[10] = 0
	elif param[10].lower() == "y":
		param[10] = 1
		param[10] = 0
	# BTU
	if param[11] == None:
		param[11] = 0.0
	elif param[11].lower() == "y":
		param[11] = 1.0
		param[11] = 0.0
	# Water
	if param[12] == None:
		param[12] = 0
	elif param[12].lower() == "y":
		param[12] = 1
		param[12] = 0
	# Drain
	if param[13] == None:
		param[13] = 0
	elif param[13].lower() == "y":
		param[13] = 1
		param[13] = 0
	# Computer
	if param[14] == None:
		param[14] = 0
	elif param[14].lower() == "y":
		param[14] = 1
		param[14] = 0
	# UPS
	if param[15] == None:
		param[15] = 0
	elif param[15].lower() == "y":
		param[15] = 1
		param[15] = 0
	# Printer
	if param[16] == None:
		param[16] = 0
	elif param[16].lower() == "y":
		param[16] = 1
		param[16] = 0
	# Notes
	if param[17] == None:
		param[17] = ''
		param[17] = str(param[17])
OUT = params
Should these just be 1 & 0 like the rest without the .0?
Duh…yep. Overzealous copy and pasting on my part!
Actually, I’m still running in to the same error with that bit fixed. Indices 2, 3, and 4 are decimal inches/12 in the Python script, but they are for 3 length parameters in the family type. Do I need to do any conversion to get usable project units from those? I’m thinking that’s the issue.
Can you share an image with the error and results visible? Everything looks good from what I can see this far, unless one of your IF statements is throwing a null somewhere.
Yep, here you go. The setparameter node is giving nulls for the length parameters and all of the yes/no’s.
I would go through and try to set each one individually. I would also try to remove the float() and divide by 12.0 to force the double. I now see False and True, did you change from 1 and 0 for the Yes/No parameters?
Yeah, I think that’s what I’ll have to do. I did switch the yes/no to boolean outputs to see if that worked w/ the parameters, but both True/False and 1/0 give me a null in the setparameter node. In the past I haven’t run in to this issue when formatting excel data for parameters, but it sure is giving me trouble on this - probably one value that is messing it up.
@SeanP so I’ve gone through and tested each parameter one by one, and they all work just fine - but when I run them all at once, the error comes up. Any idea of whats going on to cause that? Lacing/list structure?
It may be a string to number conversion issue steming from excel maybe? I’ve seen that time to time.
That should cause one of the parameters pop up as an error when executed individually though, right? None of them did.
Is there any chance you could share a sample mode, family(s),and data set?
I actually gave up on the setparameter node and handled all the parameter setting/update in the Python node. Works perfectly now :slight_smile: Thanks for helping!
I thought about suggesting that, but wanted to try and answer the question asked, but good choice!
