I was using a simple script to create a floor on a topo surface, it was working great untill I had to update it to CPython3.
The node that has broken is Floor.SlabShapeByPoints from clockwork. I ran the automatic update on the node and fixed some of the syntax. The problem is the getattr is returning false every time.
Here is the code in question.
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
def AddPointToSlabShape(item, point):
try:
hasattr(item, SlabShapeEditor) and hasattr(point, ToXyz)
item.SlabShapeEditor.DrawPoint(point.ToXyz())
return True
except:
return ‘Must Return True’
else: return False
items = UnwrapElement(IN[1])
if isinstance(IN[1], list):
if isinstance(IN[0], list):
OUT =
for item, points in zip(items, IN[0]):
if isinstance(points, list): OUT.append((item, [AddPointToSlabShape(item, x) for x in points]))
else: OUT.append((item, AddPointToSlabShape(item, points)))
else: OUT = [(x, AddPointToSlabShape(x, IN[0])) for x in items]
OUT = list(map(list, list(zip(*OUT))))
if isinstance(IN[0], list): OUT = items, [AddPointToSlabShape(items, x) for x in IN[0]]
else: OUT = items, AddPointToSlabShape(items, IN[0])
Any help would be greatly appreciated. Thank you!
