Floor or model in place from dwg
I have a floor, and i need to create a negative element, to do this…
I have a dwg with all negative drawings that i have to do…
I was thinking in 2 ways…
1º) Convert all dwg lines and create a model-in-place (empty), and after cut the floor.
I already created the lines from dwg, but can’t create a model-in-place…
and another way is…
2º) Create a floor using all lines from dwg… and after JOIN and invert JOIN.
In this case, i need help to create a floor using lines or curves from dwg.
I suppose you’re trying to do something like that?
clr.AddReference('RevitAPI')
floors = UnwrapElement(IN[0])
holes = UnwrapElement(IN[1])
polys = UnwrapElement(IN[2])
lst = []
for j, l in zip(polys, floors):
	for k in holes:
		ln = k[0].ToRevitType()
		pt = ln.GetEndPoint(0).ToPoint()
		test = j.ContainmentTest(pt)
		if test == True:
			crvArr = CurveArray()
			for m in k:
				crvArr.Append(m.ToRevitType())
			doc.Create.NewOpening(l, crvArr, True)
			lst.append("Kesilen Döşeme")
OUT = lst
Thanks for the answer.
Look, my problem is that i have no rectangles.
This is my dwg… with 8 lines
I’m using this nodes to create lines in revit…
As you can see, in the final, i have ONE LIST, with all lines…
Actually, i dont need to do holes in the floor, if was possible to create floors according the lines in dwg, it would be good.
  • "Rectangle " is not necessarily, it is sufficient for any "Polygon " code to run.
You can use it.
Capture
Look into the group curves node in Archilab as well. :wink:
