I would need to get the Deafault Thickness of the floor type but somehow I get strange numbers as result which divided by “3.28083…” gives the “correct” result. (Tried it with multiple floor types)
I can’t use the “get parameter by name” because I need to switch between german and english versions. How can I get the correct value for this parameter?
Also I tried another python script which I modified from getting a walls thickness. I would need a parameter which I will highlight on the picture but I can’t find it. I don’t even know if it could work like this also with floors. I’ve looked for it on revitapidocs.com but I haven’t found anything.
Thank You!
