we know how to create floor by room boundaries, but the problems are the columns and the door openings.
Is there a way to get the room boundaries according to the red colored region in the screenshot?
We get all elements of the rooms, create curves by intersecting the elements with a plane.
But how can we create a curve or boundary to get a finished floor like the red region?
Thank you john,
if we ignore the columns, can we get a boundary whitch uses the door openings? ( see screenshot, the red colour is by hand to demonstrate what we need)
You have to find the doors associated with the room ideally the leaf, create a line down the center of the leaf, generate jamb lines back to the room boundary, trim the room boundary line between the jamb lines, and join everything together.
Here’s the DYN I was talking about. It’s big and customized for our families, and places Roofs instead of floors (they’re better than Floors for finishes), but just prior to that it’s the same.
@P_Fiala - I’m sure yours runs faster as a result of the extra Python! Would you mind sharing?
Roofs vs Floors for Finishes
Roofs change thickness upwards, floors downwards. When you place a floor the top of the floor is at the level and you must offset it up and track changes to that offset with changes to floor thickness. With roofs it’s set it and forget it as they have their bottom aligned to the level.
When picking walls of Floors the default option is to extend to core. Most finish floors start at the wall finish, not the core, so you have to uncheck this box every time you start a new floor. You end up leaving it checked more than not. Roofs have this box unchecked by default saving you time and creating a technically more accurate model.
Wall base can be applied to roofs as fascia. You can use a slab edge to apply wall base to floors as well but when you have a space with no finished floors that still require wall base your left looking for another solution. Fascia can be applied to model lines as well so for these areas you have an integrated solution. You have to lay down the model lines first but it keeps the wall base all in one tool referencing one profile/material.
Those are my reasons why I like roofs instead of floors for finished floors. I know some (many) balk at the idea of using categories for other than what they’re intended but I see no problem with it. Filters manage visibility just fine.
I think its better one concrete floor as structural floor and then layer of room floor as floor category…with only one layer…with index of type…and then in excel have index of type with all other layer…as example index 01 - layer tiles, adhesive, cement and other…
also you can’t in floor plan add room to roofs …only floor.
P_Fiala,
your solution looks great, exact what we need. I don´t know if I will ever get there :-((
( Autodesk: this could be a great feature in Revit ! )
Not sure if this thread is still active, but I’m trying some things out with placing floors under door openings based on the correct adjacent room and your Dyn seems to look promising. I think I might be able to trim it down a bit (if you haven’t already), but I’m missing a couple of packages to get your version to run in the first place.
You don’t happen to have a list of used packages for this script do you?
Hi @J.hugelier, could you please make a new post on this topic as this one is already two years old and yours is a different subject. It helps keep this forum more organized. Feel free to link to this post or mention a user in your new thread. If you have a specific question about a certain user’s post, you can directly message them by clicking on their name/icon and click Message.
