It seems the script has an error. Can you send me the file code?
which error did you get can you show, with python in the canvas
we will need see the whole thing, and run on that sample i shared ??? try share your graph
not sure as i cant create that isssue…try reinstall mepover, or try open mep there are some flex node as well…ps i work in millimeter…
probably it could be some conflict with some other packages, you could try remove all your package exept mepover and dynamoironpython 2.7 ver 2.5…but not sure at all as i have never seen that issue with mepover, only with correct some namespaces
is it the same with pipe by lines ?
Ha, ha, ha. I know what’s wrong with this node package. The Element Type does not accept a list! I am Orange sama.
You hit it in the middle! and btw thank you
