Flatten of a (poly)surface
Hi.
Is it possible to flatten a (poly)surface or pullontoplane without creating of curves before?
My surfaces are not flat and as you can see, if i merge them and want to create perimetercurves (i need an outline) i get “wrong” lines.
image image
My hope is, that if i can flatten the surfaces so that they have the same elevation, the perimetercurve function will create a correct outline.
It seems to work with the polysurface in the back.
Hello, I had to retrieve the contour of the surface before the projection [Even if the input is a geometry], it only accepts the contour it seems (comment with reservations)
cordially
christian.stan
