Hi, trying to use this great script from https://sites.google.com/site/enjoyrevit/dynamo/farm-fence
Unfortunately im not sure how to deal with the error in this code block. My guess is I need to remove “list” from the insert column but not sure how
use DSCore.List or ArchiLabxxx.List depending on which list function you are trying to call.
Thanks DSCore.List gives no errors but i still cant get this script to run without freezing everything. The screenshot I have from the original script just had List with nothing else.
Show us your complete graph with values of each node.
Sorry it works! The problem after that was the input for the distance of the adaptive nodes. 8 was only 8mm apart and freezing up with the amount of families to input. Must have been different units in the past.
