Hi everybody,
my name is Simone, I’m totally new at Dynamo, I’m trying to doing the advanced tutorial available in the site.
I’m stucked at Unit 2 - Family by point - Part 1. I divide the isoline in U direction, making a code block as described, but when I connect the code block to the Curve.PointAtParameter it turns yellow with the following warning:
Warning: One or more of the input types are not matching. Couldn’t find a version of PointAtParameter that takes arguments of type (__array,__array)
Furthermore, if you can see it in the picture, the “zero"and the"one” number in the code block are blue instead of being black as in the video, and the "zero"symbol has the small sloped line in the center, while in the video the “zero” is more like the “O” vowel letter. May be because I installed the 8.0 version of Dynamo, of may be some keyboard setting of the pad number (even if I checked and everything seems to be ok), in any case I can’t go ahead with the tutorial, and this is quite frustrating.
I attache the image where I’m blocked.
Another thing I noticed is that in the Surface.GetIsoline and Curve.Length, I have “curve” in the output box, while in the video there is the “var” word, like in the Curve.PointAt Parameter I have “point” instead of “var” again.
Hope someone can help me out with that.
Thank you in any case
Simone
