Hello
I am trying to create an efficient way to find which room or space an element is closest to, while not needing to be inside it.
So far I have gotten the Autodesk.Revit.DB.Solid from my spaces, and insertionpoints from a few lighting fixtures.
I want to somehow see for each point which solid is closest to it, but I do not know how to go about doing this. Any tips or tricks?
I do not want to create solid geometry in dynamo, hopefully this is possible to make this graph viable for projects with 1000 rooms and even more elements.
Here is what I have this far:
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Electrical import *
from Autodesk.Revit.DB.Mechanical import *
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore.List import *
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
b = []
d = []
OUT = []
for a in IN[0]:
b.append(UnwrapElement(a))
for c in b:
d.append(c.ClosedShell)
for _ in d:
for __ in _:
OUT.append(__)
