All elements on workset
can i get all elements of these worksets starting with a FilteredWorksetCollector ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
# 🌈 all Worksets
collector = FilteredWorksetCollector(doc).OfKind(WorksetKind.UserWorkset)
names = [i.Name for i in collector]
ids = [i.Id for i in collector]
OUT = []
for i,d in zip(names,ids):
    OUT.append("{} - {} ".format(i,d))
KR
Andreas
Hi, Element class has a property
edit:
Look at the exemple 3 (blog by c. Poupin top quality as usual)
Cordially
Christian.stan
@christian.stan ,
i am one step closer :wink:
worksets = collector
OUT = []
for workset in worksets:
	elementWorksetFilter = ElementWorksetFilter(workset.Id)
	fecbyWksetId = FilteredElementCollector(doc).WherePasses(elementWorksetFilter).ToElementIds()
	#selectElemId = uidoc.Selection.GetElementIds(fecbyWksetId)
	OUT.append(fecbyWksetId)
KR
Andreas
@christian.stan ,
i think this is right a get list of list so i have to check if it is realy sorted by worksets !
	fecbyWksetId = FilteredElementCollector(doc).WherePasses(elementWorksetFilter).WhereElementIsNotElementType().ToElements()
This is the purpose of the filter
at the same time :wink:
cordially
christian.stan
@christian.stan ,
i just have to handle None Elements
KR
Andreas
I’m expected, I’ll leave you, have a good quest and evening in the elimination of empty :wink:, for my part I’ve been trying to understand the events for several days (it’s very hard for my little head)
cordially
Christian.stan
