How do I filter a family type by elevation?
I typed elevation into the search bar of Dynamo, but all the nodes relate to creating levels.
I just want to find sockets at 200mm above a certain level, so I can move them to the correct elevation of 450mm
This is how I would do it
Look at the element parameters, there should be something like a level host.
Then get all those parameters value and put them through a β==β node.
Then run that Output with the list of elements through a Filter by mask Node.
This means you can get rid of all elements that donβt equal that elevation.
Ask if this needs explaining more
Then you can repeat the process for elements with Offset == 200mm.
