Hi, I’m trying to separate the revit elements, of one type, by level. I get all the elements of 1 level and all the elements of a type. Than, I have to do the intersection of the revit elements. This is where im stuck
One more thing, when I select the elemets at one level, dynamo “understands” the low and the high bounds? cause he only shows the elevation. Like, when I put leve 2 he gets the all the elements till level 2 or the ones between level 1 and 2?
@cydkab this should help you in the right direction… Pipes & other Systems families are associated with levels via the “Reference Level” parameter. If you get that value, you can either use FilterByBoolMask or GroupByKey to separate them by their levels
