Hi all, I manage to get all the footings in the current project. But I want to filter only isolated footing from the list. So for that I used gettype but giving me the out like
I want to filter only isolated footings. Please let me know how to do that ?
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
# Get foundation
footing = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFoundation).ToElements()
footype = footing.GetType
OUT = footype
@shashank.baganeACM , hi
Maybe you can get it via visibleInCurrenedView Whats your critera for filtering you can also GetParameterByNameAndValue and filter your footings.
Online Documentation for Autodesk's Revit API: 2015, 2016, 2017, 2017.1, 2018
KR
Andreas
@shashank.baganeACM try this:
footing = FilteredElementCollector(doc).OfClass(FamilyInstance).
WhereElementIsNotElementType().ToElements()
import sys
import System
def tolist(obj1):
else: return [obj1]
# Get foundation
footing = FilteredElementCollector(doc).OfClass(FamilyInstance).OfCategory(BuiltInCategory.OST_StructuralFoundation).WhereElementIsNotElementType().ToElements()
OUT = footype, footing
hmmm…
@Draxl_Andreas It works for me.
footings = FilteredElementCollector(doc).OfClass(FamilyInstance).OfCategory(BuiltInCategory.OST_StructuralFoundation).WhereElementIsNotElementType().ToElements()
OUT = footings
Hi @tradelie it works only if a single should be (instance) should be present in the active view. But if I want the loaded families(isolated footings) then ?
Let’s imagine I have not placed any of the footings (instances) in the active view. the how to get the loaded footings ?
@shashank.baganeACM if you want the family types, you can use the family symbol instead and where elements are types:
footing = FilteredElementCollector(doc).OfClass(FamilySymbol).
WhereElementIsElementType().ToElements()
Thanks Man @Elie.Trad It worked. So to get types we need to use familysymbol.
Thanks alot. I appreciate that.
