Filter by Base Constraint
I want to filter all walls by base constraint. Please tell me why is this script not working. Why is operator returning only false values? Why is Base Constraint returning two values (Level, and Elevation) ? How can I brake that list in order to get only Base Constraint, and not level elevation?
Try to compare name to name
Hi try as Marcel suggest with compare string/string name or try something here
How can I extract the name of the base constraint?
At the blue circle add an Element.Name node
Sorry for late reply, busy days. Your suggestion worked. Thanks.
