Hey everyone.
I have a problem here with a catenary curve, which I’m using for a grotto. I found the formula for the catenary, yet there’s a missing part at the end of the curve.
I have the sense that it’s something easy to solve, but again, haven´t nailed it yet.
As always, I will appreciate your help.
@santrod0204 Can you share your Revit file and Dynamo file, I cannot replicate the same geometry you have in your example.
Hey @Elie.Trad I’ve solved it already.
I’m working in a plain “Generic Model wall based.rft”, it was just a matter of changing the first line of the catenary script. Should I delete this question from the forum?
@santrod0204 I marked it as a solution, no need to delete it.
