For some reason I am getting an error message in python that says: ‘FillRegion’ object has no attribute ‘OwnerViewId’.
The Revit API lists OwnerViewId as a property of FilledRegion class. Am I missing something?
My script is below (IN[0] is a list of filled regions)
Hi Pierre,
Can you try UnwrapElement?
This is from Clockwork:
What does UnwrapElements do?
Thanks,
It worked!
What does UnwrapElements do? Do I have to have a specific package loaded? I am asking because I’m writing a script for the office and I need to indicate whether or not specific packages should be loaded.
Please have a look here: https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration
Unwrap allows you to use the RevitAPI directly.
Hi Can anyone help?
My code is not returning an owner view.
Import RevitAPI Classes
clr.AddReference(‘RevitAPI’)
#the above can be changed to import just specific classes separated by a comma
clr.AddReference(‘RevitNodes’)
Adds ToDSType (bool) extension method to wrapped elements
#adds ToProtoType, ToRevitType geometry conversion extension methods to objects
#import documentmanager and transaction manager
create varible for revit document
elements = UnwrapElement(IN[0])
onvw =
code that modifies revit database goes here
for ele in elements:
onvw.append(ele.OwnerViewId)
OUT = onvw
FINDING LOST CAD - 13TH.dyn (6.8 KB)
