I’m trying to place rooms in a revit file based on the level and UV. I tried to follow the syntax for creating a transaction and unwraping dynamo elements that I found in the migrating to .7 document, but I’m running into an error “Expecting UV, got UV” (on the line that creates the new room). Does anyone know what this error means(code below)?
Thanks,
Nate
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
Import ToDSType(bool) extension method
app = DocumentManager.Instance.CurrentUIApplication.Application
#The inputs to this node will be stored as a list in the IN variable.
levels = IN[0]
uvs = IN[1]
for i in range(len(uvs)):
level=UnwrapElement(levels[i])
uv=UnwrapElement(uvs[i])
roomlist=[]
doccreation = doc.Create
room = doc.Create.NewRoom(level, uv)
roomlist.append(room)
OUT=roomlist
