Would it be possible to put a Filled Region over an Element on a Sheet based on the Elements Bounding Box for Example?
So let’s say for this example i don’t want the Filled Region on the View but on the Sheet?
Yes, it is possible. Something like these steps:
Thanks for this. Never there was such a thing. Hence my question. Will look into it later.
Yeah - I don’t know if there is a node for it, but there is a method in the Revit API so it is doable.
Hate to be the one to tell you, but Revit does not allow filled regions on sheets.
OMG I can’t believe I forgot this!!
@bvs1982 while you can calculate the geometry, you can’t get filled regions.
What was the reason for wanting to do it this way?
Always a work around >>>Think @john_pierson had a demo but can located it atm but was similar to this .
wow, i wish i had have known this about 30 times in the past
cheers!
