FeatureLine.Create from polyline3d
Hi,everyone! At first, I’m soory for my poor English…
Now I want to create featureline from AutocorridorFeatureline through polyline3d.
I could create a polyline3d from AutocorridorFeatureline but couldn’t create featureline from it because of error " Argument Exception : A feature line can’t be created from the entity geometry "
Here is the code. Please correct it.
existing_names = []
featureline = None
fl_name = "法尻"
with adoc.LockDocument():
    with adoc.Database as db:
            civilDoc = CivilApplication.ActiveDocument
            flColl = civilDoc.GetSitelessFeatureLineIds()
            p3dColl = Point3dCollection()
            for flId in flColl:
                fl = t.GetObject(flId,OpenMode.ForRead)
                points = fl.GetPoints(2)
                existing_names.append(fl.Name)
            for point in points:
                p3dColl.Add(Point3d(point.X,point.Y,point.Z))
            polyline3d = Polyline3d()
            btr = t.GetObject(db.CurrentSpaceId,OpenMode.ForWrite)
            btr.AppendEntity(polyline3d)
            t.AddNewlyCreatedDBObject(polyline3d,True)
            for i in range(p3dColl.Count):
                vertex = PolylineVertex3d(p3dColl[i])
                polyline3d.AppendVertex(vertex)
            index = 0
            new_fl_name = fl_name
            while new_fl_name in existing_names:
                index += 1
                new_fl_name = f"{fl_name}{index}"
            new_fl = FeatureLine.Create(new_fl_name, polyline3d.ObjectId)
            featureline = t.GetObject(new_fl,OpenMode.ForWrite)
            t.Commit()
share example [ Dynamo file and drawing ]
Thank you for your reply!
But I found another way without python script.
I look forward to your help next time!
Can you please share the information on how you did it?
Originally, the purpose was to obtain a 2D curve using the nodes of FeatureLine.Curve2D. However, we obtained a 3DPolycurve from CorridorFeatureLine and converted it to a 2D curve.
Thanks for share
