I have a question about my code that places familyinstance by points.
Problem is that is really slows down the script speed. Is there a solution to speed it up a little bit more
Attached my Dynamo code inspired by the example on this site
Can you post a sample family and rvt file which provides the level of complexity you need this to work with? My sample test fell apart quickly due to units, and I’m not sure that my case was valid (I rotated a ceiling 45 degrees to cause the isolines to not follow the ceiling edges).
With Select Model Element you have to choose the floor model you see and the family type is the one showed in the picture. It’s a very simple family so not heavy.
The first time you run the code it is slow and the second time when you change the panel size for example it’s much faster. But i don’t know why it’s slow the first time
