FamilyInstace.byFace problem
why this node can’t work with a surface from a family in linked file ?
Somewhere a lot earlier in your workstream can you try the bimmorph nodes to collect your elements and get their location?
still there is no family hosted to try to get their locations the FamilyInstanc.by face node doesn’t work
What is thr exact error you are getting?
Hi @Mariam.EmadLHT4U could it work if you try spring family instance by face ?
Revit_tsL2a2zYJh
it worked when i used bimorph nodes
this springs node previously worked but now its not working in 2024 for face from a linked file.
Be sure you have the linked face from bimorph as well it have the link reference inside for the spring node or try family instance by reference from genius loci and get the linked reference genius loci have nodes for that as well…and in 2024 be sure you have the right ironpython package installed as well, or try set the node to cpython 3 or pythonnet 3
Revit_YOqmyCM34f
Yes I used Bimorph node to access the link faces, otherwise I was getting the error that “multiple targets do not match” kind of thing.
But I will surely try this one out and let you know.
