Hi. What can I do about it? Thanks.
This is a conflict between Dynamo and a Revit add-in, specifically with Iron Python.
Are you using PyRevit? Try disabling that as a start.
Hallo @jacob.small . I am not using Pyrevit with Revit2025.
Disable PyRevit and see if that fixes it.
Thank you @jacob.small . It’s work. But can I the same time use Pyrevit und Dynamo?
did you actually have any issues or just this message? If just the message - ignore it.
