I don’t know the best location to post errors I face in Dynamo, but I was working on a procedure and I’m having issues creating the Categories node.
Failed to load built-in type
System.InvalidCastException:
Unable to cast object of type ‘Dynamo.Nodes.Categories’ to type ‘Dynamo.Models.NodeModel’.
at Dynamo.Models.DynamoModel.CreateNodeInstance(String name)
if one tries to create a node “categories” an error message shows in the message window.
workaround 1: use an old as template, remove everything but the categories node… everything is working
workaround 2: select the categories in one of your templates go edit/copy. create new workspace and go edit/paste. categories are in the house!
workaround 3: go like workaround 2; create new custom node; paste categories; save. from now you have a custom node that (at least in my enviroment) can be imported any time
I am using the latest daily build (0.7.1.25189) and it seems that the “Categories” node is still not working at 100%.
Some of the selections seem to give off errors. One example is the Views one. It gives the following error:
Warning: ElementQueries.OfCategory operation failed. View cannot be a template view.
Another problem related to views is that whenever you have a structural plan (EngineeringType enumeration), the “Document.ActiveView” gives the follwoing error:
Warning: Document.get_ActiveView operation failed. Unable to cast object of type ‘Revit.Elements.UnknownElement’ to type ‘Revit.Elements.Views.View’.
