Hi Everyone,
I am facing a problem with installing most of the dynamo wellknown packages to Dynamo for Revit 2023.
I did everything of installing different versions of the packages, also restore the privacy restriction on the JSON files from settings, but still can’t see the packages in Dynamo itself and their status in Dynamo is alway failed.
Anyone faced the same problem or has a Solution for that?
Thanks a lot
- Uninstall all your packages.
- Install one package, making sure to use a version built for Revit 2023.
- Confirm that one package works.
- if not: post the package version, your Dynamo log, and Revit journal.
- If so: proceed to install other packages, always keeping an eye on the version alignment.
Note that Revit 2023 is into the last half year of it’s supported lifecycle, so you likely shouldn’t be setting up anything new here, but instead focusing on migrating to a supported build (2024, 2025, 2026) and setting up those environments.
