Dear Autodesk Community,
I am currently facing a problem in my python script that makes me despair a bit. I already solved the problem in Dynamo. No Issues here, but I am trying to speed up my dynamo script by transfering some processes into python. The script is supposed to give the middle points of the two smallest faces of a boundingbox. However it doesn’t work. Error message says "AttributeError: ‘Face’ object has no attribute ‘Evaluate’ ". I have already tried a few things, but nothing seems to work out, and I am bit helpless at the moment. Maybe someone can find my mistake?
I would appreciate any help. Thank you in advance ![]()
from Autodesk.DesignScript.Geometry.Core import *
clr.AddReference('RevitAPI')
#defining functions
def getBBoxFaces(bboxes):
solidList = [ ]
faceList = [ ]
for bbox in bboxes:
solidList.append(bbox.ToCuboid())
for solid in solidList:
facesPerSolid = solid.Faces
faceList.append(facesPerSolid)
return faceList
def get2smallestFaces(faces):
smallestFacesPerSolid = [ ]
for facesPerSolid in faces:
smallestFaces = sorted(facesPerSolid, key=lambda face: Face.Area)[:2]
smallestFacesPerSolid.append(smallestFaces)
return smallestFacesPerSolid
def getMiddlePoints(faces):
uv = UV(0.5,0.5)
midPoints = [ ]
for face in faces:
midPoint = face.Evaluate(uv)
midPoints.append(midPoint)
return midPoints
def getMiddlePointsOfBBox(bboxes):
middlePoints = [ ]
faceList = getBBoxFaces(bboxes)
smallestFacesList = get2smallestFaces(faceList)
for smallFace in smallestFacesList:
middlePoints.append(getMiddlePoints(smallFace))
return middlePoints
# Start Transaction
#Unwrap element
bboxes = UnwrapElement(IN[0])
#get Middle Points Of bbox
middlePoints = getMiddlePointsOfBBox(bboxes)
# End Transaction
OUT = middlePoints
