mkom
June 22, 2020, 3:12pm
1
I am trying to wrap some geometry with surface that behaves like a fabric.
I found similar ideas online and was trying to follow the steps but I am getting warnings on the 1st codeblock. Can anyone point out why it’s not working?
Note: There’s one custom node called “IsLine ”
Fabric.dyn (113.9 KB)
Fabric Wrap.rvt (1.6 MB)
mkom
June 22, 2020, 4:02pm
3
Yes, those are the steps I was trying to follow, but still getting warnings.
I am trying to do that 1st codeblock with dones, but it’s not working, my coding reading is still basic.
mkom
June 22, 2020, 6:37pm
4
It looks like I found an issue that this code block had, but it still not fully working.
mkom
June 22, 2020, 7:17pm
5
It seems to be working only on round geometries for me.
Fabric.dyn (98.5 KB)
Have you checked this out?
This class will explore DynaShape, a free and open-source Dynamo package for constraint-based form finding, optimization, and physics simulation. DynaShape helps you design exciting, creative, and practical architectural forms based on understandings...
mkom
June 23, 2020, 1:29pm
7
DynaShape looks very interesting and I can’t wait to try it out.
I was looking to do this.
Dear Long,
Firstly like to say Dynashape is a fantastic set of nodes and I have enjoyed developing knowledge of its basic application, I am however looking to push it a little further.
My query how would you go about creating a conical tensile membrane as exemplified in the below image, I understand using point anchors however can we select a circle/points representing a circle as an anchors, I appreciate any response in advance.
[conical_tensile_structures_by_midascreations_d9y57q3]
mkom
June 30, 2020, 2:12pm
8
I was trying to make this in Dynamo, no luck so far.
This was made in 3Ds Max. Is Dynamo available in 3Ds Max?
I would like to work with this surface and apply various weave patterns.
Created a version that works with polygons
cloth1.dyn (14.2 KB)
obmx = obj1.BoundingBox.MaxPoint;
obmn = obj1.BoundingBox.MinPoint;
obcn = Point.ByCoordinates((obmx.X + obmn.X)/2 , (obmx.Y + obmn.Y)/2 , obmx.Z);
divs = 10;
clt2 = clt1.Translate(Vector.ZAxis(), obmx.Z).PerimeterCurves();
clt3 = clt2<1>.PointAtParameter((0..1..#divs)<2>);
cll1 = Line.ByStartPointEndPoint(clt3<1>,obcn);
cll2 = PolyCurve.ByJoinedCurves(obj1.ProjectInputOnto(cll1,Vector.ByCoordinates(0,0,-1)));
cll3 = Line.ByStartPointDirectionLength(cll2.StartPoint,Vector.ZAxis(),cll2.Length-cll1.Length);
cld1 = NurbsCurve.ByPoints(cll3.EndPoint).Length/divs;
cld2 = Math.Sqrt(Math.Pow(clt2.Length/divs,2)-Math.Pow(cld1,2));
cld3 = List.Shuffle(List.Flatten(List.Transpose(List.Transpose([List.Cycle(0,Math.Floor(List.Count(cll3.EndPoint<1>)/2)),
List.Cycle(cld2<1>,Math.Ceiling(List.Count(cll3.EndPoint<1>)/2)<1>)])<1>)<1>,-1)<1>);
dis1 = Vector.ByTwoPoints(Point.ByCoordinates(obcn.X,obcn.Y,List.MinimumItem(List.Flatten(cll3.EndPoint,-1).Z)),cll3.EndPoint);
clc1 = PolyCurve.ByJoinedCurves(obj1.PerimeterCurves());
clc2 = NurbsCurve.ByPoints(List.Flatten(cll3.EndPoint.Translate(dis1,cld3),-1),true);
srf1 = PolySurface.ByJoinedSurfaces(List.Flatten([obj1,Surface.ByLoft([clc1,clc2])],-1));
mkom
July 15, 2020, 2:05pm
10
This is pretty cool. Thanks Vikram!
What I like about Dynamo is that it gives a polysurface if I am not mistaken whereas 3Ds Max gives me mesh surfaces and they are hard to work with afterwords.
Could the cloth be applied onto multiple objects just like in the animation above?
This woudn’t work on multiple surfaces.
Will need to explore some ideas for that to happen, but not sure if I’ll succeed.
Also please note that this approach results is an approximation. Just geometry, no physics.
mkom
July 15, 2020, 5:00pm
12
Yes, geometry is what I am after.
I was trying to have the cloth over two table slightly apart, but it failed.
