Hi All,
I’ve been looking into reloading raster images during a server migration. I’ve found some info to reload raster images based on a link, however what I would like to do is expose the existing path, then run a modifier (lets say change drives from X: to Y: ) then re-link them.
The link location is not a parameter that’s exposed in the element parameters and raster images are not exposed in any node I’ve been able to find (these nodes expose CAD, RVT, IFC etc).
I think there will be a python way of doing this, however I have no experience in python.
Thanks in advance
Hey,
I think something like this should work…
#thanks to Nicklas Østertgaard nvo@bimshark.com / nvo@shl.fk
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
collector = Autodesk.Revit.DB.FilteredElementCollector(doc)
imageTypes = collector.OfClass(Autodesk.Revit.DB.ImageType)
newDriveLetter = IN[0]
relinkedImages = []
for i in imageTypes:
path = i.Path
newPath = ("".join((path[:0],newDriveLetter,path[1:])))
i.ReloadFrom(newPath)
relinkedImages.append(i)
OUT = relinkedImages
I can’t do the final bit without remaking the server path… But if I comment it out, the rest seems to work…
If you have a list of newDriveLetters we’d need to modify the code a bit.
Hope that’s useful,
Mark
