Exporting Schedules to CSV format
Hi there,
I am trying to export multiple schedules to CSV format. I have made the below workflow that works fine in my system but in other systems, the Schedules Exporter node gives a null output (in every Revit project files).
I can’t figure out the cause. Is there an OOTB workflow for the same?
This is the Python code for Schedule.Exporter, just in case.
clr.AddReference(“RevitAPI”)
clr.AddReference(“RevitAPIUI”)
def tolist(obj1):
if hasattr(obj1,“iter”): return obj1
else: return [obj1]
schedules = UnwrapElement(tolist(IN[0]))
path = IN[1]
exportTitle = IN[2]
exportColumnHeaders = IN[3]
exportHeadersFooters = IN[4]
opt = ViewScheduleExportOptions()
opt.Title = IN[2]
if not exportColumnHeaders:
opt.ColumnHeaders = 0
opt.HeadersFootersBlanks = IN[4]
i = 0
for s in schedules:
n = s.ViewName.ToString()+“.csv”
s.Export(path, n, opt)
i=i+1
OUT = i.ToString() + " schedules exported"
Hello
the View.ViewName property is deprecated in Revit 2019 (remove in Revit 2020).
  • Replace by View.Name property
Thank you. Could you please mend the script or perhaps point out where is this property?
I don’t know much Python.
for s in schedules:
	n = s.Name +".csv"
Thanks @c.poupin. It works fine in Revit 2020.
Earlier I was using Revit 2019 for exporting.
