Export to NWC not referencing object
Hi Guys,
I have attached my script that uses data shapes to point to file location and output folder for nwc files. I have a 3d view in the model that is specific for nwc export hence the view filtering. it all appears to make sense and outputs are as expected, the issue is that when it is run the exporter node appears to not recognize either the file or view
and returns non referencing object. Hoping someone can review and give me a solution here. any help is greatly appreciated.
I have the OOTB NWC exporter installed.
Export nwc by selection.dyn (97.7 KB)
It is hard to see the problem without data in nodes. Is it possible for you to share a screenshot of your Dynamo project with the node output panels pinned?
I think it has to do with handling views as i am filtering out views that i do not want but it is returning string?
