Export to multiple excel sheets error : iteration over non-sequence of type category
Hi all, I’m trying to export the data in multiple sheets by using BB Data node from Bublebee package. But when I run the script, I receive the following error.
iteration over non-sequence of type category.
Not sure how to fix it, can anybody help, please. Thank you: slight_smile:
You aren’t using any of the formatting features, why not try using the OOTB nodes instead? So long as your lost structure matches it should work fine here.
Hi Jacob, thanks for the reply, I’ll look into it. Will share the feedback soon.
Data that you are feeding into the first node is just a single item. It’s not a list. The error is pretty self-explaining. You are giving it a single item, but it’s trying to iterate over it. Put that thing into a list, and problem should go away.
