Hello all!
This is my first post in the forum.
For the last few days i’m having a bit of trouble, looking in this forum for the solution to this problem that I have, although it helped me to learn a lot and understanding things I did not know, I still do not know how to solve it, so I am here asking for a hand.
I am trying to export Groups of Sheet Lists separately to Different DWFx files at the same time.
The Tool.ExportDWF node flattens the lists and exports everything in a single file, but I need each group exported in a different file with a different name.
I put the node Tool.ExportDWF inside a Custom node to be able to pass a list of sheets and file name at the same time and an index to use it as a function (https://forum.dynamobim.com/t/loopwhile-and-functions/7401)
The custom node seems to be working, but only passes the values once by exporting a single group of sheets to a file.
(I tried to modify the Tools.ExportDWF to add the loop inside, but my python knowledge is even scarcer.)
Thanks in advance
