Hi, Alll
I use the python code for export DWG file from Sheet view. but script is run successfully but DWG file not export in that folder.(see image)
please help me…
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference('RevitAPI')
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessParallelLists(_func, *lists):
return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
def Unwrap(item):
return UnwrapElement(item)
folderPath = IN[0]
if isinstance(IN[1], list):
views = ProcessList(Unwrap, IN[1])
views = list(Unwrap(IN[1]))
if isinstance(IN[2], list):
names = IN[2]
names = list(IN[2])
RunIt = IN[3]
#Predef = IN[4]
#Version = IN[5]
def ExportDwg(name, view, folder = folderPath):
options = DWGExportOptions()
options.FileVersion=ACADVersion.R2007
options.MergedViews=True
views = List[ElementId]()
views.Add(view.Id)
result = doc.Export(folder, name, views, options)
return result
if RunIt:
try:
errorReport = None
# run export
ProcessParallelLists(ExportDwg, names, views)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
errorReport = 'Please set the RunIt to True!'
#Assign your output to the OUT variable
if errorReport == None:
OUT = 'Success'
OUT = errorReport
@robert12546358 either run the script under IronPython2 or convert the script to CPython3 before running it,
do not just run it in its current format under CPython3 engine:
