Export point file
Hi, I used the dynamo “ZeroTouchImage” scrypt to extract the points from an image. How should I export this points into an external file(for revit)?
Cattura
For what do you need these points?
You could export them to excel and than create a topographie with the normal Revit functions.
How could I export them to excel?
Why do you wish to extract to an external file (excel) when Dynamo have direct access to Revit?
I need these point to create a polyline (on a wall) in revit
You can create the polycurve directly in Dynamo from the output you have:
Then all you need to do is to create/apply it to you wall in Revit.
Thank you, I will try this solution
@Jonathan.Olesen I’ve replicated your nodes, but i obtained a wrong connection of the points. Is there a way to connect the nearest point?
You could try sorting the points by their average vector and a Nurbscurve with a low degree instead?
Either what @Ewan_Opie suggests or sorting your points in regards to their distance from each other.
