Export many sheets from Revit to DWG with specific name
I’m trying to export a lot of sheets from Revit to AutoCad, the thing is that once i do the exportation I need to change the name of the .dwg file in order to meet the requierements of the office, so basically what i looking for is to export every single sheet with a specific name, that is located it in a Shared parameter inside the sheet.
Thanks in advanced
Hi @proyectos,
This is possible with custom nodes.
Here is an example :
Hi Alban!
I have to made some modifications in the inputs but it works perfect!
Thank you a lot
