Export/import text from Revit to Excel
Greetings,
I have to export all text from view (with their ID) to excel file and change them inside cell then import the same location inside view.
The reason why I need that code is re-edit all texts inside model. The model is in English and we will change them inside excel and make it double language and then import to same location and allign.
Is there any dynamo script for this?
Thanks for support.
If you create the script yourself and run into problems, we will try to help you.
In the forum rules you will find that this not a “we will do it for you” place.
Please show what you have tried.
Hi Rijsmus,
Got it. I will create a script and put it here.
Thanks.
Hi
How you done this yet?
There are an exhaustive number of forum threads that discuss the topics of Exporting Data to Excel as well as Importing Data From Excel. I would recommend reviewing what’s been discussed, giving it a go, then creating a new thread if you are stuck on specific steps. Since the original poster has not posted to the forum since this thread (from a year ago), it’s fairly unlikely that you’ll get a response.
