I have a script set up that grabs all 3D views in my model, and filters them if they have a specific View Type name. I want to then use the Export to FBX node to export each individual view as a separate FBX file. It seems to work and it creates the files, but it seems to combine the views with each export. So the first FBX is correct, the next FBX combines the 2nd view and the 1st. The 3rd FBX combines the 3rd, 2nd, and 1st, and so on. Am I missing a step so each view exports just as itself and doesn’t combine with others?
I’m having the same issue, did you find a workaround?
The only workaround I could get was I had to call out each view to a separate Export to FBX node, like in the attached screenshot. I couldn’t figure out how to get a list of views and plug it into one node without it combining the files. It’s a bit of a pain, but still easier than exporting each manually.
