Export Excel
Hello, how to create a numerous Excel Exports at once? I need to transfer a set of Lists to individual Excel Files, due to a chart and graphs generating. Basically first values from Lists are creating a chart which cannot be affected by continuous values from a List as they are linked to those in the same order.
If I don’t misunderstanding, it can be solve by List Create and List Transpose.
You will have to do this with Lacing, List Levels and a good list structure, but it can be done. For instance, make sure all data for first Excel file is all under “0” index, the next “1”, etc then use Levels to write the correct data and format.
