I’m going to go dig around, but I just saw this is possible from an updated plugin and I want to add it to my batch plot…
So on further investigation, you are required to enable ‘views as references’ to make the plugin work (you also have to specify a template). Not ideal, but I guess that’s the way in…
I am exporting to shared coordinates but the views aren’t taking notice, I’m not sure why.
Any assistance gratefully received.
I’m using a modified Python from @Alban_de_Chasteigner via Archi-lab via Genius Loci, at the minute… Here’s it further edited…
# Copyright(c) 2016, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference('RevitAPI')
import System
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ProcessParallelLists(_func, *lists):
return map( lambda *xs: ProcessParallelLists(_func, *xs) if all(type(x) is list for x in xs) else _func(*xs), *lists )
def Unwrap(item):
return UnwrapElement(item)
folderPath = IN[0]
if isinstance(IN[1], list):
views = ProcessList(Unwrap, IN[1])
views = list(Unwrap(IN[1]))
if isinstance(IN[2], list):
names = IN[2]
names = list(IN[2])
RunIt = IN[4]
Version = Unwrap(IN[5])
dwgExportOptions = str(IN[3])
mergedViews = IN[6]
#if mergedViews == True:
# sharedCoords = False #if we're going to export views separately, we'll want them in Shared Coordinates
#else:
# sharedCoords = True
def ExportDwg(name, view, folder = folderPath):
options = DWGExportOptions()
options.FileVersion=Version
options.GetPredefinedOptions(doc, dwgExportOptions)
options.MergedViews = mergedViews
options.SharedCoords = True #sharedCoords
views = List[ElementId]()
views.Add(view.Id)
result = doc.Export(folder, name, views, options)
return result
if RunIt:
try:
errorReport = None
# run export
ProcessParallelLists(ExportDwg, names, views)
except:
# if error accurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
errorReport = 'Please set the RunIt to True!'
#Assign your output to the OUT variable
if errorReport == None:
OUT = 'Success'
OUT = errorReport
Cheers,
Mark
test.dyn (27.1 KB)
