Good morning,
I notice that since the 2.16.1 update the “Export as image” command does not work.
Have you noticed this problem?
THANKS
Bit confused because there are a few export as image tools around… which export as image command? Export a Revit view? The Dynamo workspace? The Dynamo geometry? Something else?
Hello @jacob.small
In Dynamo.
THANKS
Huh… failing for me as well. Well that’s going to be rather problematic… Interestingly 2.17 works in sandbox. Already pingged development.
For now you can try and get workspace images from sandbox and/or Dynamo for Revit 2022. Hopefully we’ll hear of an easy fix as I use this in all my work (been entirely in Civil 3D and older Revit builds the last few months so hadn’t run across this yet).
You can use instead the File (Fichier) tab.
The export workspace as picture function is working here.
I remember this bug and the export menu items from top menu should work instead of shortcut item. Please let us know if this work around does not work, sorry for the inconvenience.
@Alban_de_Chasteigner beat me on that
Great catch Alban, Christian, and Aaron!
Yes it works from the menu bar.
Thank you all.
