Export a list of elements as a Revit selection set
hello, is there a node, or a way to export a list of elements as a Revit selection set ? or, similar, have them selected in filter and highlighted?
Export as a Revit file? Or just a list of element Id’s?
Just quick export to csv is better, for python can get selected element from revit :
#Copyright(c) 2016, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
def output1(l1):
	if len(l1) == 1: return l1[0]
	else: return l1
selid = uidoc.Selection.GetElementIds()
OUT = output1([doc.GetElement(id).ToDSType(True) for id in selid])
ExportExcelElement.dyn (12.9 KB)
Thanks, I was meaning to get the listed elements from dynamo selected and highlighted back in Revit?
Hi @fotista …think genius loci have a node called show element, probably is what you need
You do know Revit has a tool built in to do this(?)
that’s exactly what i was looking for, thanks a million Søren ,
