Explode Node removes properties from objects within Block References -> how to code explode yourself (properly)?
You can send the regular explode command to the command line if that helps: How to use civil 3D commands in a Python Script? - #3 by mzjensen
Here is an example: Issue with SendCommand and MapImport - #5 by WrightEngineering
