[Solved problem myself: there was a part of the namespace name missing in the icon titles. ZT and nodemodel icon adding works in the same way.]
Hey guys,
I have a question about adding icons to Explicit Custom (or Node Model) node packages:
How do I get icons on the nodes? I’ve tried using the same logic as with Zero Touch (https://github.com/DynamoDS/Dynamo/wiki/Add-Icons-for-a-Zero-Touch-Assembly-or-NodeModel-assembly) but that doesn’t do the trick.
I worked through the list of issues I had for ZT nodes, but without result (see Zero touch add icons error).
Is setting the icons for this type of node any different than with ZT?
Any ideas anyone? Thanks again for the help
