I wanted to run simple rotation command but it gives me the attached error message. I watched following tutorial and it works in the video and seems very simple. I did not get what is wrong with the rotation command. Kindly provide support if possible.
Hello, the nature of the object restricts you (look at the incoming), you can use a package (Genius Loci, here, you will also have to install DynamoIronPython 2.7 to 2.5 some nodes are written in IronPython)
Sincerely
christian.stan
thanks a lot, that works like a charm.
