I have encountered this issue before with using Geometry nodes in python. In the past I just decided to use the nodes instead of python; however, with this instance it would be too many nodes. I have tried everything I can think of including flattening any inputs involved.
Any help is appreciated. Thank you
error:
code:
inputs:
Just remembered about List.Map so I will be able to do my solution with nodes; however, Iād still prefer to use python. If anyone knows a solution please let me know. Thanks!
Flattening will still return a list, so you can get the first item by indexing either before you use it as your input, or by indexing the input in your python script.
next(iter(list))
you can that line of code above on your pt
