Hello friends, I’m trying to access the list of X-Coordinate value from the list of Points in python script. But when I run the script it shows the following error. Would appreciate if could share their experience opinion. Thank you
Your input is an entire list and a list does not have a .X attribute. You’ll need to iterate over the list in your python script and then use .X on every item in your list.
listout = []
for point in StartPoints:
listout.append(point.X)
OUT = listout
Thanks @T_Pover. I was wondering what’s wrong with my following code. Why it is not giving me the correct output.
StartPoints = UnwrapElement(IN[0]) #List of start points of each line
EndPoints = UnwrapElement(IN[1]) #List of end points of each line
NewStartPoints = []
NewEndPoints = []
for i in range(len(StartPoints)):
for j in range(len(EndPoints)):
if ((StartPoints[i].Y) == (EndPoints[j].Y)): #This code is not working, WHY?
NewStartPoints.append(StartPoints[i])
NewEndPoints.append(EndPoints[j])
OUT = NewStartPoints, NewEndPoints
That;s because the Y values are inaccurate due to rounding issues, you will have to check if their values are almost equal.
Yes, I thought that so. I was thinking there might be some work around for it. Anyway what I did was cast the values to integer than compare it. After that it was working. Thank you for your help. Appreciate it : -)
if (int(StartPoints[i].Y) == int(EndPoints[j].Y)):
