Hi there,
I’m inserting and Image in all the titteblocks. The thing is that it works for one sheet and one point, but when I try to do it for a list of sheets and points doen’t work. Any help? Thks
Hi there,
Well there is couple of options here. First you could iterate over the input, assuming that it’s going to be a list. Secondly you could try wrapping that python node into a custom node and then use the new type casting for inputs. I believe that defining your input as var[] in a custom node input will do the trick and allow it to process list inputs. You can also look at an answer that I have posted on Stack Overflow that had a similar issue: LINK
Thks Konrad,
I’m gonna study a little bit, python is a new world for me.
Hi Konrad,
Python is too much for me right now. I’ve tried but no luck.
I’ve try the socond option too, so I did next but still doen’t work.
