How can i exit from the
- python
- python in dynamo
- C# code (this need probably exit from application - not from programm)?
1.) example for python code in dynamo - if list IN[0] is empty - exit programm or exit from code (its just try)
check_inn= **break** if not IN[0] else do it...
2.)or how apply GOTO in python for example (this need ignore/skip -this part of code - > do it…)
check_inn= **goto label 1** if not IN[0] else do it...
do it...
label 1:
OUT="done"
------ but in python 2.7 we cannot use this : from goto import with_goto
